Welding cast steel
Welding cast steel
I need to weld a piece of cast steel to a steel plate and I am not sure if I need to change weld wire. Do I need wire with similar carbon equivalent? My casting has an equivalent of ~.25 which I know is weldable, but I have been told that I need to change wire to more closely resemble the elements in the cast steel. How close do the elements need to be?
RE: Welding cast steel
http://www.welding-advisers.com/
