Dimension Names and Drawings
I need to show Dimension names when I create design tables but when I create a drawing i have to turn them off to print it.
Is there an easier way?
RE: Dimension Names and Drawings
When you're applying the dimensions in the sketch rename them and then you will know the name for DT creation
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right."  -- George Best
Why? I definitely agree with giving the dimensions names, but to populate a DT all that is needed is to click on the dimension (or use the Auto-create option). The name only really becomes relevant to make the DT easier to understand.
cheers
SW07-SP3.1
SW06-SP5.1
I can certainly understand why you would want to toggle visibility of dimension names.  We use highly configurable custom purchased parts all the time.  The part number that we purchase by is a 4 character alpha shape designator, 2-3 character alpha material designator, then a long string of dimension names and values.  It's easy to build the part number using named dimensions and a design table.
That said, I assume you are wanting a one-click solution.  You can map this macro to a button.  It will toggle display of dimension names.  Enjoy!
CODE
Sub DimNameDispToggle()
Dim swApp As SldWorks.SldWorks
Dim swDoc As SldWorks.ModelDoc2
Set swApp = Application.SldWorks
Set swDoc = swApp.ActiveDoc
swApp.SetUserPreferenceToggle swShowDimensionNames, _
    Not CBool(swApp.GetUserPreferenceToggle(swShowDimensionNames) + 0)
swDoc.EditRebuild3
End Sub
