Help doc on Solaris 8
Hello All,
Currently using CATIA V5 R16 on solaris 8. Can locate help file through file manager.
Unable to call help from within CATIA V5. Help -> CATIA V5 Help.
Checked CATDocView variable. It is set to "/usr/DassaultSystemes/B16doc" and language is set to "English".
Select the help option within CATIA, the busy signal appears for 5-10 seconds then dissapears. Nothing happens.
Any help much appreciated.
RE: Help doc on Solaris 8
Tools - Options - General - Help
Clear out the technical document area.
OK
Press F1
if the technical doc area is empty, catia will prompt you to locate it.
Browse and find path up to the B16doc directory.
Derek
Derek
PeterGuy,
Have tried that method numerous times and failed as Derek says.
Derek,
Will try this out when back in the office.
Scott.
It works with MS Windows and AIX5.3 but not Solaris 8!!
Any other suggestion ? ?
CATIA version is 5 release 16.
Don't tell me you think it is down to the browser being used . . . ! ? !?
Can access the documentation the manual process - file manager -> /usr/DassaultSystemes/B16doc/ . . .
Even created a link on workspace!!
I am at a customer site, I can't install netscape to try.
Derek
