External UGto2D
External UGto2D
Is there any way to configure extrenal translator UGto2D to have the same behavior that the convertion made in unigraphics with the 2D exchange?
RE: External UGto2D
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
RE: External UGto2D
I would like to translate several file at the same time, and the result of these file should be the same type of translation of 2d exchanche inside unigraphics.
I am using NX4.
RE: External UGto2D
I'm not positive whether this will work or not for batch translations, but it's the first thing I would try.
The results may vary, depending upon the settings you have set for the external translator. I rarely use it so I'm not quite sure what to tell you to do.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: External UGto2D
The interface for the dwg/dxf translation is the real problem here:
It would be intersting to have the same type of interface translating UGto2D drawing than the type used in DXF-DWG translation.
the diference between them is that ugto2d will translate a 2D drawing file and dxfdwg translate crete and autocad file with 3D and 2D drawing in it.
Since I need to translate the file so machining people can open it in spin fire I only can open 2D drawing file so...
I know this is probably very difficult to achive but it would save me hours of manual translation.
thank again
RE: External UGto2D
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
