Imported Part, Build a Tree?
Morning,
Apologies if this has already been asked, or is a commonly asked question.
I am a new Catia user, having been on Solidworks. Solidworks comes with a feature called Feature Works, if you import a .step file for instance, you can run this module, and it will build a model tree for you. Doesn’t always work very well, but it gives you a tree to modify.
I was hoping somebody could tell me if Catia can do a similar trick?
Thanks in advance,
Thanks in advance,
RE: Imported Part, Build a Tree?
http://www
Derek
