How to prevent a triac from causing Incandescents lights to flicker
I currently have a 100 ohm and .1uF across the MT1 and MT2 terminals of the triac and currently have a flickering occurring. When I am connected to building power =no problem. WHen I am connected up to a generator that's when i get the problem. DO I know have sufficient snubber across the triac?
RE: How to prevent a triac from causing Incandescents lights to flicker
You may not need any snubber depending on what your load is.
More info..
Keith Cress
Keith Cress
I am using a zero cross detector chip placed at the front of my ac input connection, to detect AC voltage zero cross for phase control. I would think the RC snubber on the front end would delay the zero cross detection for every 1/2 cycle??
Maybe I could place a snubber circuit at the mains distribution (input) that feeds 3 light dimmer circuits?
Sometimes I only open my mouth to swap feet...
whics depends on frequency.
Fuse:
You nee, I'm afraid, a more complicated scheme -- so back
to the drawing broad.
Why don't you tell us what you are trying to do ?
Please read FAQ240-1032: How to ask a meaningful question
My WEB: <http://geocities.com/nbucska/>
