Rubber cutting
Rubber cutting
Rubber cutting
Does somebody know what I should use to cut rubber 3/8'' thick stuck into a wooden flume? I heard that a concrete saw with a steel blade and using water + dishes soap will prevent the rubber to stick on the blade.
Thanks for advises.
JP.
RE: Rubber cutting
Try to freeze the rubber first.
