FACE AND BYPASS AHU APPLICATION
I need your help with the following:
I'm involved in a Hospital project where the disigner has especified a dedicated ahu's for each OR's..without any
any reheat...at this stage of the project provide hot water or electrical reheat is almost impossible. I was thinking to provide ahus with face and by pass.
Would be a good solution to use face and bypass ahu for this aplication. The project is in south america.
RE: FACE AND BYPASS AHU APPLICATION
What are you thinking?
Can you describe it more in depth please?
It's a chilled water system...
Now I have second question...will a heat pipe system work for this application..do you have any experience...
Thank you again.
Everything is possoble. When there is a will, there is a way (even in south america). Reheat for an OR is your only bet in my opinion.
If you have a pre-heat coil, you should be able to get reheat, don't you? heck, you can actually power your electric reheat from the emergency generator if you have to.
Could you elaborate on your situation a little more? weather data, room temp, ACH requirements, design criteria, what are your available utility sources? etc..
