AASHTO Bridge 16th and 17th edition differences
The PE exam this spring references the AASHTO Standard Specifications 17th edition, but I only have access to the 16th edition. I will use what I have, but are there many differences or changes wrt the code itself, does anyone know who wouldn't mind commenting on them?
RE: AASHTO Bridge 16th and 17th edition differences
If you have most/all of the interims for the 16th Edition then your copy will be fairly close to the 17th Edition (with a few subtle changes). Even without the interims, you may still be OK, but you are taking a small risk.
My experience has been that the Bridge questions on the PE exam are fairly basic (retaining walls, distribution factors, impact equation...that sort of thing). Chances are very good that your copy will work for the basic questions that you are likely to see.
