Speed of a spring
Speed of a spring
We have an application where a spring is not able to close our worksholders fast enough. Is there a way to work out the speed of an extension spring? If we put a second identical spring working in conjunction with the original, will it work faster?
Is there a ratio between the tension of a spring versus the speed?
Kieran
Kieran
RE: Speed of a spring
Cory
