What is the convrsion factor for leakage rate unit Pam3/sec ?
Dears
What is conversion factor for leakage rate unit Pa.m3/sec ? and what is the definition of this unit. Is it some like mass leakage rate? Any reference?
RE: What is the convrsion factor for leakage rate unit Pam3/sec ?
The SI units are standard cubic centimeters per second for pressure and torr liters per second for vacuum.
This quantity is a measure of volume leakage as a function of pressure.
Reidh
I want to convert it to cc/sec for instance to check leakage criteria for intake manifold. I need to know if the criteria is 100 Pa m3/sec and the pressure is 3 bars what will be the leakage flow in cc/sec.
Reidh
