Engine lube pump
Engine lube pump
Anyone who could describe me about lube oil pump, that is; directly coupled to engine shaft which could provide uninteruptible lube oil flow though its bearing. Does this configuration is reliable? What type of pump?
Any good thoughts?
Thanks..
Any good thoughts?
Thanks..
"Whenever you are asked if you can do a job, tell them, certainly I can! Then get busy and find out how to do it." Theodore Roosevelt.
RE: Engine lube pump
Cheers
Greg Locock
