Axisymmetric model : Deflection discrepancy with standard formula
Hey guys,
I can't seem to figure out where I'm going wrong. I analyzed an axisymmetric model subject to a uniform load along a circumference and compared the resultant deflection with the textbook closed form solution, but there's a huge difference. The modeling seems simple enough!
The disk is annular and is pinned at the outer radius (ux and uy = 0. The loading is per unit circumference along the inner radius of the disk.
Disk dimensions: (dist from axis of rotation)
Inner radius: 700 microns
Outer radius: 2000 microns
Thickness: 200 microns
Material Properties: E = 7.31E10, Poisson's ratio: 0.333
I modeled the disk section as a 2D axisymmetric shell with 8 noded quad elements. The loading is applied to the inner radius. I started off with a load of 10. (I'm guessing ABAQUS takes that as 10N per unit circumference?).
ABAQUS solution: around 130 microns
Closed form solution: 0.218 microns!!!
What's weird is, I kept playing with the load - increasing it by a considerable order of magnitude, but there seems to be no change in the deflection. I'm pretty confused at what's going wrong with my model! :(
RE: Axisymmetric model : Deflection discrepancy with standard formula
Principal - http://www.OnlineFEASolver.com
General FEA Consulting Services
What is the meaning of the thickness for a axis-symmetric model ? I do not follow.
Thank you for replying. I actually meant it's the height of the section, not the thickness. I'm pretty sure abt the consistency of the units.
I played around with the model a bit - I realized that I had ramped the load linearly over the step when I had to put an instantaneous force. I changed that in the step module, and turned nlgeom on - but there still is a difference from the correct value.
I uploaded the file onto ur site as you asked, thank you for that. It's named as Axisymmetric TEST. I've used different dimensions from the ones stated above for convenience.
I think turning nlgeom on has solved most of the discrepancy. However, the ABAQUS value is nearly half the calculated value (from the closed form solution). This error seems to be consistent for different variations of the model.
Any ideas why?
When I query the node at the inner radius, I get scaled and unscaled values of deflection. Now, do I multiply the unscaled value by the scale to get the actual displacement? Or is the unscaled value the correct answer?
Yeah, but the ABAQUS deflections are different from the actual values. I can't understand the source of the error.
I input the load for the axisymmetric model as the entire Load i.e. Load per unit length multiplied by the circumference on which the load is applied.
For example in the above model, you obtained a deflection of 1.01 microns, whereas the actual answer should be 1.23 microns. This error increases as I increase the disk dimensions.
related to mesh density. How about trying fully integrated
elements, i.e remove the 'R' from the element type.
Thanks again :)
