Implementing a script into an ODB session
I have a python script file which i want to implement to my ODB session. I open my ODB file and then I went to File Run Script and then I selected my file However the CAE closes immeditely and an error is decleared.
How can I treat this matter please.. any specific procedure to implement a script into ODB
Merci
RE: Implementing a script into an ODB session
This could be for any number of reasons. You'll have to provide a bit more info - e.g. what is the error message that is being printed to the system window?
All I see is "ABAQUS /CAE GUI exited with an error"
I tried to open the script through the ABAQUS system prompt C:\
 (respecting the place in which it is saved and requesting it from that place)
but still no success it says" Cannot open Field
Is there any error message in the abaqus.rpy file?
I suggest you download the the python GUI from www.python.org
it allows you to check your python script and usually pick up the error that ABAQUS do not pick up. e.g the line indent is wrong.
