Hydraulic Valve Assembly Standards
Entering into the brave unknown and specifying a new pressure reduction valve / custom manifold assembly.
Our old tech specs here callout the use of JIC H-1 (1973) as the only technical standard. This has been replaced by NFPA T2.24.1. After searching the NFPA site my head is spinning from the assortment of titles contained therein.
Can any suggest a select few appropriate standards I should have in hand if I'm going to create a purchase/design spec for custom manifolded assembly of press. reduction valves, check valves, & needle valves?
A map to guide through the forest of paperwork would be appreciated.
Frank "Grimey" Grimes
Rule 25. of Swanson's "Unwritten Rules of Management"
Have fun at what you do. It will reflect in your work. No one likes a grump except another grump.
