CATIA V5R16 - License with 64 Bit workstation
I now have a new work station to setup. It is a 64 bit INTEL Xeon with XP professional. My license and files are on a server running window 2000 server. I have installed CATIA V5R16 on the new work station, however, CATIA is not finding the license. On my older workstation (32 bit)it seems like all I did was to install CATIA and go. Any ideas?
RE: CATIA V5R16 - License with 64 Bit workstation
You need to run the LUM to configure the licenses.
Ben Loosli
Sr IS Technologist
L-3 Communications
Have you done any real benchmarks, or it just "feels" faster?
Just thought it might help those trying to evaluate making the jump to 64bit.
Dual Core and dual processor mean nothing to Catia. I would suspect that you are used to a sluggish x86 system, because all the "speed" is based on a single processor, unless you are running certain DMU or FEA apps, as has been discussed at length in the past.
Overall, I'm very pleased with 64 bit Catia, although I don't base it on actual benchmarks - just actual use. However, I could not be UNhappier about the choice of operating system. X64 has been a nightmare in terms of finding drivers for certain devices, namely anything wireless. (that's only ONE example)
Catia Design|Catia Design News|Catia V5 blog
By the way, Natester - you mentioned your operating system was XP Professional. If it is not 64 bit edition, your machine may be 64 bit capable, but you are in no wise running 64 bit. Also, you did not mention 64 bit Catia, only 64 bit hardware. Did you mean to say that you are using 64 bit Catia?
Sorry if I misunderstood you...
Could you kindly suggest what type of computer would best suit the 64 bit Catia? I plan to convince my management to make the switch but I would like to be armed with some data.ie what type video card, processor etc
I apologize but I am not really a "computer" person, and have limited knowledge in this area. Any suggestions would be greatly appreciated.
thixoguy
Personally, we use - and like - AMD Opteron. Our machines are IBM Intellistation A Pro. However, these are very expensive machines, and unless you buy older model or refurb, you won't have much luck convincing management to go for this.
I don't have enough experience with 64 bit on anything else to give much of an opinion. But here is one of our setups: (my favorite) Dual 2.8GHz AMD Opteron, 4GB RAM/processor, Nvidia Quadro FX4500 video. The AMD machines don't have as high of a clockspeed as Intel, but their architecture doesn't require the higher number for the same performance. Plus, no front side bus, because the memory is directly accessed by the processor. The dual processor doesn't do anything for Catia performance, but it is nice for running multiple apps with no system slowdown. (or multiple Catia sessions)
I'm afraid you'll have to ask someone else for Intel advice. Probably that's the better bet for budget. The AMD's are about 2-3 times more expensive than a comparable Intel. But they are ideal for 64 bit computing.
Thanks for the info, it is much appreciated
thixoguy
As I said earlier, 64 bit Catia requires 3 things:
1) hardware with 64 bit architecture
2) a 64 bit OS
3) 64 bit Catia
This may seem like the obvious, but a lot of people seem to overlook at least a couple of these...
Also, when I noted that the dual processors (or dual core) don't do anything for Catia performance, I was only talking about Catia not being coded for dual processor. 64 bit Catia has some distinct advantages for performance. There's no noticeable gain on basic tasks, but for long part trees, DMU, and file translations, there is night and day difference.
The Dassault Website has a huge list of certified computer configurations,I will have my IT people reference them.
Thanks again, I'll let you know how things work out.
thixoguy
2. The CATIA installation on this computer is V5R16, 64 bit.
3. The Pro/ENGINEER installation on this computer is Wildfire 3.0 - M070, 64 bit.
I am not really using this computer at this time due to the fact that there is many other applications that need to be installed at this time.
That's a pretty silly, question, to be quite honest. Why not? It happens all the time. Especially given the fact that most new hardware is 64 bit capable, and Operating systems like Vista and x64 have proven, as of yet, to be a pretty big disappointment. It is not at all unreasonable to think that MANY people or companies may be buying 64 bit hardware, yet using 32 bit operating systems.
This may be even more true in large companies where migration is an issue. (isn't that right, catiajim?)
Dell sent me a 64bit to try before you buy. Dual Xeon with 16Gb ram Quadro 4500 w/512mb. 72GB (I believe) Scsi drive. The only Dell in the company (IBM people). Works great. I can spec things out, but that is not how it works at my place of business. You put a request in, sometimes things show up.
Derek
The IT people are getting me some quotes, I'll mention the try before you buy scenario you suggested. Perhaps before I finalize any order I'll post what I'm getting and solid7 and yourself can advise. Thanks for input, it is always appreciated.
thixoguy
You might also want to look at License Statistics ( http:/
It's pretty good software to track the licenses to track all sorts of issues. We enjoy it a lot.
-- Poul
