Solidworks tangent lines in drawings
Hello I am new to this site and these forums but I was wondering if someone could help me out. I am using Solidworks 2006 and I am trying to show some iso views of cabinetry for a customer and each of these views are shown in "Shaded with edges" so I can show the wood grain etc. however it also shows the tangent lines in my prints and I don't want that as it can be mis interpreted by the customer for break lines instead of tangency. I have tried the "tangent edges removed" command but that doesn't work in "shaded with edges" view and I would use just shaded but it doesn't look that great.
RE: Solidworks tangent lines in drawings
Also which video card and driver?
SW07-SP3.1
SW06-SP5.1
First off...welcome. You'll find a lot of professional help in this forum. The guys and gals her are great!
Second, are you sure all the geometry is tagent? You might want to go back and verify that.
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
No Radeon card is certified for use with SolidWorks. They will work to a degree, but anomalies will be seen sooner or later.
Best I can suggest is to try different drivers to see if that alleviates the problem.
SW07-SP3.1
SW06-SP5.1
http://lancegunter.com/for%20forums.jpg
*CAD, CAM, 3&5 Axis CNC, Design & Engineering, Marine industry.
*M6809, AMD 64 3200+, Radeon 9600, 2x 512ddr, Windows XP pro.
*Solidworks 2006 SP 0.0
*AutoCAD 2007
*Autodesk Inventor 10
*Pro Engineer 2000i2
*3DSMAX 7
Colin Fitzpatrick
*AutoCAD 2007
*3DSMAX 7
http://img
SW07-SP3.1
SW06-SP5.1
*AutoCAD 2007
*3DSMAX 7
Good news is that it can be done ... in SW2007-SP3.1
Bad news is that I could not do it in SW2006-SP5.1
Time to upgrade!
SW07-SP3.1
SW06-SP5.1
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP3.1 on WinXP SP2
*AutoCAD 2007
*3DSMAX 7
Look to the right of this webpage and you'll see a MVP list of SW's top dogs. I'm not one of them, but do help out once in a great while. These folks are the Pro's I was talking about.
Also, FYI do a search on past threads to see if your question has been already answered. We hate repeat questions that have been already answered in great detail.
Welcome again!
Colin
Colin Fitzpatrick
In your picture it doesn't look like a tangent line to me. It looks like the edges of two parts.
Add the view to a dwg, make shaded, then hide the line per macduff's suggestion.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-08-07)
(FYI--might be a bit of a limitation in an upgrade, but I wouldn't expect to see variable fillets in cabinet design, either.)
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Jason
Jason
You’re my hero, and thank you! It's nice being appreciated from time to time. Have a good weekend.
Best,
Colin
Colin Fitzpatrick
SW07-SP3.1
SW06-SP5.1
