User Pattern from Sketch Error - File Inside
SW2006  SP4.1
Here is the link to my part.  I was only able to make a sketch driven pattern with the revolve and not the rest of the features:
http://www.mediafire.com/?etenzjxjmin
My approach:  create all the geometry needed for the pattern.  Create the revolve, create the extrude/stiffener, fillet stiffener, circular pattern of stiffener, Sketch driven pattern of above features.
RE: User Pattern from Sketch Error - File Inside
It's the filetts which are preventing the pattern.
You will have to apply the fillets after making the pattern,
cheers
SW07-SP3.1
SW06-SP5.1
I did try what you mentioned and that worked.  Thanks
