allowable stress in stainless
I have a small structure  where we are going to use stainless steel plates to make I and T shapes to use in the frameing.  Is there a standard for determining allowable stresses in stainless?...would it be reasonable to follow the AISC steel spec?
RE: allowable stress in stainless
For stainless steel framing, you might want to check directly with AISC and local building Codes to determine if they have specifications for using stainless steel. I have seen specifications and building Codes regarding use of stainless steel, although it was more applicable to decorative versus structural.
You can go through the NIDI.org or SSINA.com web sites to find information on SS in structural application.  I don't recall the source for the info difectly.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
