3CR12 (1.4003) v 430 (1.4016)
Hello
Looking for advice on which material would be most corrosive resistant in an environment where it is in contact with a liquid with a pH of 4.0 but is also being dried out periodically. I would also suggest that the liquid is likely to be around 50 Degrees C in temperature.
Thank You.
Thank You.
RE: 3CR12 (1.4003) v 430 (1.4016)
Cory
The lower Cr grade has some advantages, easier to weld, tougher, but you give up noticeable corrosion resistance in return.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
