Pump up equation?
Pump up equation?
I am trying to determine how long it would take to pump air into an open bottomed barrel(100 cubic feet) in a tank of water 230 feet deep. (Say a silo)
I know that the psi at that depth is approx 100 psi.
The pump will be located below the tank so there will be minimal amount of hose needed.
I have a 25hp pump pushing 100 CFPM.
How do I calculate this???
any help would be greatly appreciated.
RE: Pump up equation?
I even went so far as to contact a few air pump manufacturers and was told by the chief engineer (which I highly doubt) that all it would do is aeriate the water........
Again, thank you very much.
