heat of soultion for high concentration HCl exhaust
I am doing a process design for a acid scrubber. Selected absorbent is water.Now the problem i faced is i can't find the heat of solution data for HCl in Perry Handbook because the temperature rise of the water will impact the efficiency greatly. Can anybody help me to find the solution heat data of HCl exhaust?
RE: heat of soultion for high concentration HCl exhaust
17.8 kcal/mol HCl  at infinite dilution
16.2 kcal/mole HCl at 10:1  water:acid
11.4 kcal/mole HCl at 2:1   water:acid
Thanks a lot, can you tell me where can i find suck kind of data?
Landold Börnstein ISBN 0-387-07443-0, 1976, heat of mixing
(where I picked the data
or DECHEMA series
or use a process simulator
