Versa-Check install starts when SolidWorks is opened
I use Versa-Check to print accounting checks on a blank form. For some reason, every time I open SolidWorks, an Install window opens, and begins to install Versa-Check, even though Versa-Check is already installed and runs properly. I've un-installed and re-installed both SolidWorks and Versa-Check. Any ideas?
RE: Versa-Check install starts when SolidWorks is opened
You might receive more insightful replies from the Tek-Tips site. Try Microsoft: Windows XP Pro Forum forum779.
SW07-SP3.1
SW06-SP5.1
