Sea Water Pumps
Sea Water Pumps
All:
I am in the process of determining cooling water pressure.The system basically consists of tunnel which collects water at 20m depth, the interface will be at the intake pit.There are several users and it is pumped back to the discharge tunnel. I have assumed my discharge elevation at 10m below datum.
What should I take my source elevation? Do I have to perform pump hydraulics for pressure determination.
Any help would be appreciated
npf
npf
RE: Sea Water Pumps
Re "source elevation" - this would depend on your pump location RELATIVE to the source. Now you can "make a datum" and reference all elevations to this. This may allready have been done so you just "inherit" it - or you choose - e.g. pump inlet=0 or surface of water=0 or.... whatever seems practical to you
If you have to perform "pump hydraulics" - well that is for you to deside
Best regards
Morten
RE: Sea Water Pumps
Thanks for your inputs. This is my first project on sea water pumps.Right now the pump would take suction from 20m depth.
I have couple of concerns:-
What pump orientation would be desirable(horizontal or vertical)?
Would source pressure be (depth *SG/2.31)?What static head should I use to determine my suction pressure?
Where would the pump location be?
Any comments would be appreciated
npf
RE: Sea Water Pumps
What you are asking is meaningless and as we don't have a crystal ball to see what you are attempting to do - how can be give any meaningfull answer.
A simple sketch of what you have in mind would go a long way in helping us to help you.
Make a sketch, photgraph or scan it and post it using the following link. http://www.freeimagehosting.net/
