locked rotor on repulsion motor
Hi:
I have an older 3hp repulsion motor. Whem starting it, with or without load, the rotor locks. When I give it slight push, it works normal. I checked the armature and the 4 brushes and they were clean. Since the brushes are movable, I tried them in different positions to no avail. The winding on the rotor looks normal with no discoloration.
Thanks in advance for your input,
Windbug
Windbug
RE: locked rotor on repulsion motor
respectfully
