Assembly BOM/ VBA Question
I am using Lenny's AssemblyBOM macro, which I find very useful.  I started modifying the macro so that I can output all of the properties that I want to show up on the excel file.  The problem that I am having is that if the property name is two words the macro will not run.  About half of my property names that I would like to export are two words.  Is there anyway to modify the code so that I can keep the two word property names or am I going to have to change the names of my properties?
Thanks in advanced for the help.
Brian
RE: Assembly BOM/ VBA Question
Never mind I figured it out.  I just had to open the macro up twice and everything worked.
