In low Carbon steel does compression increase grain size during anneal
First Post NOOB!
As a rule of thumb can grain size be increased during batch annealing by point loading the material and adding compressive load? i.e. if I have 200 Tons being annealed in a stacked batch situation and only 60% of the bottom surface is supported, will the points that see all the load have different grain growth?
RE: In low Carbon steel does compression increase grain size during anneal
