Annealing 304 SS
Annealing 304 SS
I have an Exhaust manifold on an automotive application
that frequently sees temps. of 1700 degrees. I know that
this is not the best grade of material to use, but it was
what I had laying around at the time. After a period
of heat cycles the material seems to get brittle and
cracks. If I try to anneal this pc., will it help
with the longetivity of the pc.? Or, will annealing
the material not be beneficial? Is there anything that
I can do to this pc. that would help it survive these
temps?
Thanks for your help.
Steve
temps?
Steve
RE: Annealing 304 SS
If your material is already brittle and cracked the annealing will not recovery your TP304
brittle?
Thanks Again.
Steve
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
