Drawing doesn't fit to screen
This is more of an annoyance than annything but sometimes when I create a drawing and do a zoom to fit the drawing is off to the left or towards the bottom like there is something hidden preventing the drawing from fitting fully to the workspace. Any ideas?
RE: Drawing doesn't fit to screen
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-08-07)
Anyways, you may have an empty drawing view, or some sketch entity off the drawing template area. You may also have the wrong template for the drawing size you specified.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
1. Use you mouse and try grab "something" in the open area opposite to where the drawing is located. If there is something there, delete it.
2. If not, then right the drawing and select "edit sheet' and try again.
Remember...![[idea] idea](https://www.tipmaster.com/images/idea.gif)
"If you don't use your head,
your going to have to use your feet."
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Curious ... did you try my suggestion? I have seen it fix this problem.
If not, it is geometry lurking somewhere.
Chris
AutoCAD 06
I can't grab anything with my mouse. I have also tried to switch template sizes back and forth with no luck.
SW07-SP3.1
SW06-SP5.1
Do you have configuration in the part?
Bradley
SolidWorks Professional x64 2007 SP3.1
Intel(R) Pentium(R) D CPU
3.00 GHz, 3.93 GB of RAM
Virtual memory 12577 MB
NVIDIA Quadro FX 3400
