Codes and Standards for Subsea Structures
I'm getting ready to move more into the structural design side of the business (PLET,PLEM, and Manifold Design). My education centered mainly around fixed and floating offshore structures so I am pretty familiar with relevant API codes for platforms, but are there specific codes for subsea structures? I did a search but only found codes for subsea controls that didn't really get into the structural design of the equipment.
Cheers,
Kat
Cheers,
Kat
RE: Codes and Standards for Subsea Structures
In addition to these we often have to met the requirements of classification societies such as DNV or Lloyds, and warranty surveyors such as Noble Denton. They also publish structural design 'codes' which we work too. I use the word codes lightly because the generally specify the types of load cases , factors, and other things you must consider and refer you back to bonafide codes. The are often not just considered with the permenant works, but also the installation and transportation (seafastening, lift analysis, rigging, padeyes etc)
There is a lot more in terms of subsea specific codes when you look at subsea piping (Norsok U-001, PD8010 etc).
Some of the things we look at that may not be considered in Topsides stuff is fishing loads (making structures overtrawlable), anchor loads, dropped object loads, ROV Loads, hydrostatic collapse,
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
