Extract part from feature?
In the past I have used SDRC-Ideas and was able to extract a part from a feature on a part.
Can this be done in solidworks? I have a feature sketched on a part that really should be a part reporting to an assy.
I know I could cut and paste the skecth and pick a plane.
Any suggestions?
Terry
SW 2007 SP2.2
RE: Extract part from feature?
You can create a library feature and refer to the library if it's something you use commonly.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
