bearing classification
Is there an international system for bearing classification? I am trying to identify some needle roller bearings in an assembly as part of my degree studies.
I presume that a manufacturer would buy in bearings rather than make them in house, and I presume that these bearings are made to set sizes rather than being bespoke for every job? I have found various British Standards which describe the sizing of bearings but nothing which classifies them, nothing which gives them a name!
I know this is a really obvious question, and is probably something which is just taken for granted in industry, but could someone please tell me, how are bearings classified!
RE: bearing classification
Most used bearings are manufactured by SNR and SKF (worldwide leader me think)
SKF offers an online catalogue that you may see at that address : http://www.skf.com
SNR ownes a website too : http://www.snr.fr/GB/GBPAGES/SOMBASE.HTM
I don't think they got any online catalog there, but you may ask them in the contact section.
Hope it may help.
If needed, you can email me.
FrenchCAD
Université Joseph FOURIER
Département Génie Mécanique
Grenoble - France
cyril.guichard@wanadoo.fr
These norms are about the dimensions.
Like French said, SKF is one of the world leaders, try to get a hold of a general catalogue and you will find most types. There is a description of the ISO Dimension plans and the coding contains the Diameter series, the dimension series and the width series.
Most Manufactures will have a coding system close to SKF, and every good shop has cross reference books for interchangebility of brands.
Steven van Els
SAvanEls@cq-link.sr
gearguru
There are classifications and many type of bearings,
Tapered Roller Bearings, Ball Bearings, Conrad style
Ball Bearings, Needle Bearings and these are often
further divided into thrust bearing, radial bearings,
or combination bearings which handle both thrust, radial
an momemt loads. Some are slim line types with very
thin cross sections, and others are heavy duty and may
have bolt holes drilled in them to mount them, some are
pressed on a shaft. Probably more information than
you need.
Bearing Inc. puts out a catalogue and has many of
the different companies products. They also have
listed products which supplement bearings like pinions, belts, timing belts, collars, grease, etc.
If you look in Thomas Register, you will also find different types listed there.
i.e. plastic, steel, airfilm, some which are nothing
more than bushings.
