R value for adjustment
hi,
I have client's specification for a structure to performe in case of OBE and SSE level earthquake, which is as follows:
EQ type    Str. behaviour     Damage
OBE      Post-elastic      Minor deformations, repairable
SSE      Post-elastic     Severely deformed,no collapse,not operational
For the above case i am not sure how to adjust "R" value for my structure (pipe rack with concentrically braced frame in both dir.).
Like if my structure is to perform elastically then i can use R=1, and for post elasic R=3.25, but for the limitation of damage as stated above, what % of R value should i use in OBE & SSE cases.
