creating entorphy
creating entorphy
I was wondering if there is a process or system which can be set up which only gives off entorphy. I know that entorphy is a by product of an irreversable process and that heat and work are the outputs that make the process irreversable, yet I would like to be able to just generate entrophy.
RE: creating entorphy
One thing for sure, we all have more entropy today then we had yesterday. Entropy is always increasing in a system if left to itself. One thermodynamic definition of entropy is: Function of the state of a system whose change in any differential reversible process is equal to the heat absorbed by the system from its surroundings divided by the absolute temperature of the system. I am not sure this helps you but maybe you could check a thermo textbook for more..........Bill B.
William H. Bernhart, P.E.
bill.bernhart@tycoelectronics.com
I work as a senior development engineer for AMP - Tyco Electronics located near Harrisburg, PA. I help design interconnections for areospace applications.
BYYY
If we look at the very definitions of work and heat, it is the "pulley work" which defines thermodynamic work. So, as an example, if we take an empty box, fill it with gas at a pressure greater than surrounding's and isolate it (which means no heat or work should escape from or into the box), box becomes an isolated system. Now, puncture the box (or make a small hole/outlet which has smooth curvature so that heat does not generate when the gas escapes from the box), and allow the gas to escape until steady state is reached. Obviously, final pressure between the box(system) and the surroundings(atmosphere) will be the same. But the escaped gas cannot enter the box and bring the pressure to its initial value "automatically" without external work. As entropy can be defined as unavilability of work that has been done, "free expansion" discussed above may be considered as a process where no heat or work is done but entropy is still generated.
I hope I answered your question and I welcome any comments or flaws in my reasoning or understanding of this tricky concept of entropy from anyone!
BYE
essentially we are not jumping around like children with boundless energy at the age of 37 (at least i am not) so it is a parameter that becomes greater as time goes on....WHY ??
maybe tooooo deeep
Kieran
What exactly do you mean when you say that you want to generate Entropy only ?? Is it that no other change should take place in the system ?? That, I don't think is possible in a sense because after all entropy is something which is generated as a result of a spontaneous change in the state of a system.
However a different approach is possible ... as you might know ... the state of a system made up of a pure substance can be defined by two independent properties. Now what could be done is that you take a sealed container of gas at a certain temp greater than the ambient ... let it cool down in some open space ... then, when the temp reached ambient ... just heat it up to the orginal temp ...as far as the container is concerned, some heat is added to it and some lost ... so there is no entropy change and the container is back to its original state ... but the overall entropy of the universe would have increased because of two irreversible processes ...
There is some level of ambiguity in this explaination and if anyone wants a discussion, please feel free to mail at vipul203@bigfoot.com
Vipul Mathur
If anyone wants any help in Programming or some easy mech stuff ... don't hesitate in knocking on my door ... at any time of the night.
Heat transfer is another good example ...
Gordan
