Making a brass alloy
Can someone tell me what the best way to melt copper and zinc together is?
Thanks in advance.
Thanks in advance.
RE: Making a brass alloy
With the melting point of copper being 1083 and zinc having a boiling point of 907, I wanted to know the best way to melt the 2 together to form an alloy.
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
There is no reason to fully melt the Cu first. You would be better off if you can melt a small amount of brass to start with. You will keep the melt temp lower and loose less metal.
Don't underestimate the Zn fumes. You don't want to be breathing this.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Mike Halloran
Pembroke Pines, FL, USA
Starting materials should be small pieces & mixed to enable rapid alloying to lower the zinc activity & vaporization.
Preheat the melting pot or crucible (a gas flame works), load the charge, and cover with an inch or so of borax. Acts as a flux, holds the zinc vapor in, and is inexpensive.
w/o some premixing of the solid pieces and the use of flux, zinc losses are high:
"The appropriate amount of suitable copper alloy scrap is weighed and transferred into an electric furnace where it is melted at about 1,920°F (1,050°C). After adjusting for the amount of zinc in the scrap alloy, an appropriate amount of zinc is added after the copper melts. A small amount of additional zinc, about 50% of the total zinc* required, may be added to compensate for any zinc that vaporizes during the melting operation..."
http://www.madehow.com/Volume-6/Brass.html
*my highlighting. 50% loss is absurdly high.
For fluxing of copper & zinc, see
Molten Light Metal Processing: Part Two
http://www.key-to-metals.com/Article84.htm
Of course, you need a few foundry tools for stirring, skimming off flux and slag, etc.
My be a stupid question but I'll ask anyway, am I wasting my time by trying to melt the copper with a blow torch?
I have a small amount of copper scrap (very small pieces) and I want to melt the copper down but cannot afford a kiln/furnace and only have a propane blow torch and I have heated the copper in a metal dish for a good few minutes and it goes orange but no further.
What metal do you have that may be inert toward copper? Graphite or the cheaper clay-graphite may be better. Use a crucible with a lid to hold in heat & zinc vapor (along with the flux).
It takes some investment, and more heat than from a handheld propane burner, to melt copper alloys. The least expensive set-up:
Of course, need protective gear, etc. See http://www.webcom.com/sknkwrks/foundry.htm
And, what is the point of simply melting the alloy? To cast white hot liquid metal w/o proper equipment & experience may lead to the emergency room of the local hospital.
The picture looks remarkably like my own set-up, except I have a 12x12 hard firebrick tile as a hearth/base, my burner is driven by a small blower, and the insulating firebrick box is wrapped in a batt of mineral fibre insulation.
The trick is to have a proper crucible and a safe means to lift it out of the box- don't bother even trying to do this in a "metal dish".
The borax flux is essential not only to keep the zinc losses down but also to flux (dissolve) the oxides from the scrap you're melting. It's a bit tricky to skim the borax off the melt prior to pouring- still figuring that one out.
My boss has given me a plaster paris (gypsum) mould and said the brass (around 850oc) would be able to cast in that but I am a bit skeptical.
Foundries have special plaster mixes that are more permeable than plaster-of-Paris; this lets air escape from the mold better during filling.
Any presence of moisture in the mold can be disastrous.
" All that is necessary for triumph of evil is that good men do nothing".
Edmund Burke
I do all my castings in sand- roughly 20:3 mix of silica sand and bentonine (or ground cat litter), moistened gently to the point where a clump of sand squeezed in the hand can be broken cleanly in half without crumbling.
