Full Tension Compression Joints
Guys, how do you characterize full tension compression splices as to its electrical resistance and temperature measurement? Are there standards as to the limits of its resistance and temperatures? Thanks in advance.
RE: Full Tension Compression Joints
I don't think any field acceptance test would normally be done except for inspection to ensure that the compression was complete and smooth. See http://ww
