File Translation : Pro/E-Catia
Dear Friends,
I have a Catia model which I need to work upon. I have Pro/E with me. Is it possible to open the Catia model in Pro/E & what will be the quality of the data imported?
Is it possible to export a Pro/E drawing in such a format so that it can be opened directly in Catia?
Amish
Amish
RE: File Translation : Pro/E-Catia
See your help file on what you need to do to directly import catia models (under pro/interface I think).
At the moment I import from catia using IGES but this gives me dumb models.
The answer to your second question is no. you will have to export your drawing to IGES or another neutral format for catia to read it.
Hope this is of some help
So, I divide my translations into two categories:
1. When I need to be able to modify the resulting geometry, I use a native file translator, like the one mentioned above.
2. When I only need a solid for packaging or insertion into another part, I use a neutral format (STEP is preferred, but IGES works).
Recneps
