Design/Visualization Mode
Hi All,
I am working in a very large assembly which is comprised of several sub assemblies so I must work in cache mode as I cannot open the entire assy without Catia crashing. There are links between parts in several of the sub assemblies. My question whenever I change data in a part in one sub assembly which is linked to parts in other sub assemblies, how can I be absolutely sure that all models are up to date. What I have been doing thus far is changing each subassembly from visualization to design mode, updating the entire sub assembly, saving and then turning it back to visualization. I find this very time consuming but it seems to work. Is there any way that I can identify only the files that need updating so I need to only load those files? Can anyone suggest some best practices?
Thanks in advance,
thixoguy
Thanks in advance,
thixoguy
RE: Design/Visualization Mode
Check out Tools --> Parameterization analysis, there is a filter for waiting for updates.
Derek
thixoguy
