solidworks electrical routing equivalent to AutoCad Elect?
I have solidworks 2007 and am having a hell of a time trying to figure out how the electrical routing works.
I want to be able to go between a 2D wiring schematic and a 3D layout, similiar what is being shown in the attached link.(Demo of AutoCad Inventor electrical Routing)
Please looks at this demo video for AutoCad. Can Solidworks 2007 do this as well? As far as I can tell - the answer is no.
http://do wnload.aut odesk.com/ us/autocad electrical /2007Demos /POINTTOPO INTDRAWING CREATIONWI THAIP.html
http://do
RE: solidworks electrical routing equivalent to AutoCad Elect?
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-08-07)
If you look at the AutoDesk Demo video, you see a 3D model of an electrical enclosure with 7 connectors in it:
3 DR connectors
2 IDC connector
1 DB9 connector
1 Molex connector
At the beginning of the video you see a 7 branched blue colored harness lying in the enclosure.
The user imports wire schematic data (xml file).
From/To lines appear showing pin to pin connections (each connector has several pins).
The user selects “Auto Route Wires” and the model updates The pin to pin connection lines are re-pathed through the blue harness. The 3D model looks just like a real life assembly.
I just want to know can Solidworks do all this.
I can see how to create the equivalent of the blue harness using a
From/To file,
Cable/Wire file,
Component File.
But I don’t see anything in the Solidworks routing comparable to the “Auto Route Wires”.
Chris
AutoCAD 06
h
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP3.1 on WinXP SP2
that link helps a lot :)
I am always looking for Routing stuff. A star for you. I have not seen this one before. I am tasked with setting up SolidWorks Router for our group. Management wants it and most engineers and designers do not. I know this will work, so I am assigned the task.
Bradley
SolidWorks Professional x64 2007 SP3.1
Intel(R) Pentium(R) D CPU
3.00 GHz, 3.93 GB of RAM
Virtual memory 12577 MB
NVIDIA Quadro FX 3400
Let us know how it goes. I'm curious about performance on larger assemblies. This is probably something we could use as well....currently we draw splines to repersent wiring and get length information.
Jason
SW07-SP3.1
SW06-SP5.1
Not very good.
The kind of thing I am trying to understand is how to create one of the cables shown in the video demo
h
If you look, there is a cable coming out of the power supply terminating at what looks to be a 20 pin molex connector. You can actually see all 20 wires going into the molex connector.
Is the molex connector a "part" with 20 connection points?
OR
is the molex an "assembly", a plastic piece with 20 pin parts, each part having a connection point?
If you look at any of the connector models provides by solidworks as part of the routing add_in you only see parts, and each part has only one connection point.
Biggest thing is is setting up all your locations in Tools\options and under Routing options
Basically
Start a cable connection you just click\ Routing\Electrical\Standand Cables - select your connector type and wire diameter/length, select "insert cable" the location of the connector 1 and then Connector 2.
Your finished with the first wire... that is the basic way to put a wire into SW.
I plan to take time to learn more of this, just hard to find the time too around here.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
Where did you find a tutorial on SolidWorks Router? I looked in SolidWorks and on the SolidWorks Web site. I did not find anything. Would you be so kind as to show me the path?
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
SW07-SP3.1
SW06-SP5.1
Yes, I looked at those, which will help. I was thinking of a tutorial similar to the one SolidWorks has under help. Those are really getting to be cool.
Bradley
I work for a VAR so I get all the Tutorials for my training, but I think you can purchase it from your VAR at a cost. Unless they are offering training, which your VAR might be.
Otherwise might just call and see what their pricing is on it... Unless you are sweet talker :D
www.scottjbaugh.com
This sounds like a real good plan. What would I ask for?
I was thinking “Do you have SolidWorks routing tutorials for self paced training, that I can do in my office?”
Bradley
You might look on Ebay too... I have seen some people sell their old manuals.
www.scottjbaugh.com
http
Chris
AutoCAD 06
ctopher's home (updated 04-19-07)
Bradley
