Moving the Schematic Blocks Library
I've got one node locked V18 full version and 2 V19 2d users that are just getting started. I'd like to move the symbol libary from my harddrive to a server so they can access it too. Will that screw up the way SE works? Is there a particular way it needs to be done?
RE: Moving the Schematic Blocks Library
Just make sure they don't open the library dft files and save them otherwise you (V18 computer) won't be able to use those block libraries.
