drum pumps for haz. mat'ls
Hello
I am in the process of looking for two drum pumps, one to be used on sulfuric acid and one to be used with 32% potassium salt in methanol. I need the potassium methylate drum pump to be speced as a hazardous location as methanol is highly flammable in addition to being classified as highly corrosive (xp motor with high corrosive pump). The other sulfuric acid drum pump is a highly corrosive but low flammability and high reactivity (air driven motor with high corrosive pump).
Below are the estimated NFPA ratings:
1) Potassium Methylate (32%)
Health: 3
Fire: 3
Reactivity: 2
2) Sulfuric Acid (98%)
Health: 3
Fire: 3
Reactivity: 2
If anyone has any recommendations for drum pumps to be used for these materials, along with what kind of relief systems I can find for the drum vents themselves, I would appreciate it.
Thank You
Health: 3
Fire: 3
Reactivity: 2
Health: 3
Fire: 3
Reactivity: 2
Thank You
RE: drum pumps for haz. mat'ls
If anyone could confirm this (we don't want to have to use an xp electric motor if we can avoid it), that would be great.
I would look at some other storage for the H2SO4 like tote or tank rather try to pump out of drum. The high SG of the acid make gravity a good mode of transport depending on your lay out.
As for the H2SO4 we might do a gravitational feed but we'll be using even less of that than the CH3OK.
Stonecold
GOOD LUCK
