How do I filter Points out of an OpenBody within VBA?
I am trying to improve a VBA utility so that the program will filter out all of the points, regardless of their typename, out of an openbody that is selected by the user. An example of this would be selecting an openbody of points and vectors that represent a fastener pattern. The points can be made my the point, intersect, or project function. I only want to work with the points within the openbody; so, I've tried to use 'FilterCorrespondence' with a 'Point' or type string identifier, to filter out the points from the selection. I get a 'not a valid VB function for this even though it shows up in the options list after the 'Selection.'. I've tried serveral things to reliably segregate points with no luck.
Code snippet:
If TypeName(SelectedPoints) = "HybridBody" And Selection3D.Count = 1 Then
    Set SelectedPointsDoc = CatDocs.Item(Selection3D.FindObject("CATIAPart").Parent.Name)
    PointCount = SelectedPoints.HybridShapes.Count
    Selection3D.Clear
    For j = 1 To PointCount
     Selection3D.Add (SelectedPoints.HybridShapes.Item(j))
    Next
ReDim SelType(0) As Variant
SelType(0) = "Point"
Filter1 = Selection3D.FilterCorrespondence(SelType)
<<<Dies Here
RE: How do I filter Points out of an OpenBody within VBA?
Try This.
But bear in mind that if the result of projection or intersection is a point you will not find it easily.
Sub CATMain()
Set cPoints = New Collection
If TypeName(SelectedPoints) = "HybridBody" And oSel.Count = 1 Then
    Set SelectedPointsDoc = CAtDocs.Item(oSel.FindObject("CATIAPart").Parent.Name)
    oSel.Clear
   Dim SelType(0)
         oSel.Add (SelectedPoints.HybridShapes.Item(j))
       bRes = oSel.FilterCorrespondence(SelType)
        If bRes = True Then
            cPoints.Add oSel.Item(oSel.Count).Value.Name
        End If
        oSel.Clear
    Next j
End If
For Each p In cPoints
oSel.Add p
Next
End Sub
Thanks 'nev99', that worked perfectly; but, you were right about the 'intersect' and 'project'. I really hoped that it would see when these were indeed points. The 'Point-Type' that is used on the Selection allows the user to pick intersects and projections when they are points, I thought this woluld work the same. I've tried 'Vertex' and 'CATIAPoint'. No luck. Any ideas would be appreciated.
OK. I have a workaround using the following provided the intersect or project does not create more than one point.
Try this. It does not even use the .FilterCorrespondence method
Sub CATMain()
'---Find and filter points no matter if
'---result of intersection or projection
'---if intersection or projection create
'---more than one point they will be ignored
Dim coords(2)
Set CAtDocs = CATIA.Documents
Set oSel = CATIA.ActiveDocument.Selection
Set SelectedPoints = oSel.Item(1).Value 'Note assumes set alraedy selected
    oSel.Clear
Set oSPA = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
 Set m_Obj = oSel.Item(1)
Set ref = m_Obj.Reference
Set TheMeasurable = oSPA.GetMeasurable(ref)
On Error Resume Next
TheMeasurable.GetPoint coords
If Err.Number = 0 Then
     cPoints.Add oSel.Item(oSel.Count).Value, oSel.Item(oSel.Count).Value.Name
Else
Err.Clear
End If
Enjoy
Nev
Nev
Thank you so much. That 'work-around' works great. I really appreciate the help and speed of your response.
Cheers
