castaway parts
castaway parts
Is there a feature of SE to detect parts removed from a design that still exist in the folder system? Sometimes I try several part designs before I'm happy with one and I would like to cast out the rejects.
BTW what do other of you do when composing a design? Do you find you create many parts that you don't use?
Jef
Jef
RE: castaway parts
here is one that searches for orphans:
Orphans
HTH
dy
RE: castaway parts
Tried it out and seems to be just the thing for me.
Jef
RE: castaway parts
This then makes it easier to remove the ones I'm not using from the folder.
Also (assuming you're not using some kind of PDM/PLM just windows file structure) I always put files I no longer need in a 'junk' folder. I don't usually delete till the end of the project as more than once I've got confused and deleted the wrong thing.
RE: castaway parts
