Viewpoint Export
Viewpoint Export
Viewpoint Export
Is it possible to export a custom UCS viewpoint to another part or assembly file?
P.S. Why has the forum search been down for so long?
Specs, Intel Pentium M 2.16 Mhz
SW 2007 R2.2
1.5 Gb Ram
NVidia GE Force GO 6800 256Mb
RE: Viewpoint Export
I don't know how you could export a UCS, nor understand why you would want/need to. Perhaps I'm not understanding what you really mean.
You can create multiple Coordinate Systems in both parts and assemblies.
cheers
SW07-SP3.1
SW06-SP5.1
Basically I have an assembly and a part, and I have a custom isometric view in the assembly, and I want to be able to view the part from that same isometric view same point of view.
Hope that clears it up a little bit.
SW 2007 R2.2
1.5 Gb Ram
Yes that clears it up completely. You don't need a UCS just a custom orientation view.
How did you create the custom view in the part? Approximately with the mouse, or via the arrow key increments, or ???
cheers
SW07-SP3.1
SW06-SP5.1
I just rotated the Assembly around then I hit the space key and created a custom orientation. I guess if I used the arrow keys I could record my keystrokes and reproduce in the other file. Is that what you were getting at Corey?
Cheers
SW 2007 R2.2
1.5 Gb Ram
That's one method I was thinking of.
The other was to create a matching angled plane in the part which could be used to orient the view in the assy.
cheers
SW07-SP3.1
SW06-SP5.1
It's so crazy it just might work.
SW 2007 R2.2
1.5 Gb Ram
lol  ... OK Pistachio ... let us know if it does.
cheers
SW07-SP3.1
SW06-SP5.1
