Equation Syntax Needed
Is there a list (other than the help file) of commands for equations?
I need to convert and answer I’m getting from feet/inches to just inches.
I’m dividing a referenced dimension, which comes in feet/inches, and need a unit-less answer.
RE: Equation Syntax Needed
A possible simple workaround;
Create a second reference dimension and set its units to inches, then use it to propagate the equation. The second dimension can be deselected as Mark For Drawing.
cheers
SW07-SP3.1
SW06-SP5.1
Duh!  I whish I would have thought of that an hour age!
