USB to Ethernet IC
USB to Ethernet IC
USB to Ethernet IC
Does anyone know of a simple IC that will convert USB to ethernet?  I know there are little adapter modules out there but I want to put the adapter IC on the PCB I am designing.
Thank you
RE: USB to Ethernet IC
Perhaps there are dirt cheap microcontrollers that include both interfaces that could be programmed for this function?
Ethernet is hard. A standard microcontroller would not have the required PHY. You are probably best to use one of the modules and mount that on your pcb as a sub-assy.
