tubing end treatments in weldments
I have a question regarding weldments.  I have a structure made up of various size tubes.  Corners with the same size tubes, or at least two of the same size tubes and other smaller tubes, don’t pose a problem for me.  I can treat the corners in the normal fashion – miter the two largest tubes and then butt the smaller ones using the larger tubes as the trimming bodies.
However, when I have one large tube and other smaller ones, I can’t trim it.  I get an error asking me to check my selections.  See the image below.
 http://i46.photobucket.com/albums/f144/kkundra/corner_jnt_dissimilar_tubes.jpg
  In this case, how do I treat the corner so all the tubes are bird-mouthed (trimmed) like they would be in real life?
Kris
RE: tubing end treatments in weldments
Maybe create zero offset surfaces from the smaller tubes, knit them to create one surface and use that as a cutting tool.
cheers
SW07-SP3.1
SW06-SP5.1
