Tilt-Up Panel with 2 differing thicknesses
I've got a situation where the panel thickness needs to be 7.25" from finish floor to roof and 9.25" below finish floor to footing (-4'-8"). The client requires that the dock wall extend 2" beyond the exterior face of the building. Ideally, I would like to have one continuous panel for the full height.
Can this be done? Only idea I had was to place a foam filler/block into the form work to create a void for 2"... creating the recess in the exterior panel face.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
RE: Tilt-Up Panel with 2 differing thicknesses
Easier to put the stepped face on top.
