Customer requirements regarding stud and nut combo
the customer requested this:
A193 B7M/A167 2HM stud and nut combo, with the nut zinc plated. does this make sense?
the nut and bolt material do not match correct? can someone clarify why exaclty?
RE: Customer requirements regarding stud and nut combo
Mike Halloran
Pembroke Pines, FL, USA
Seems odd to me, calling out a stainless plate spec for nuts then plating them. I'd clarify with the customer.
Mike
The customer is always right.....but frequently has typos
The most common nut used in my opinion, for an A193 B7M stud is an A194-2HM nut.
Other combinations may also be suitable......
Galling is sometimes a problem with stainless fasteners.
My opinion only
-MJC
