PIPeline qustion
PIPeline qustion
What is "through Conduit" mean when referring to Pipeilne gate valves?
RE: PIPeline qustion
There are several advanatges: 1) affords minimal pressure drop, 2) there are no areas that can accumulate trash that might impede a pig or restrict the valve's motion, and 3) speaking oif [pigs, it allows a pig to pass thru.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
Instead of a "wedge" that comes down into a seat, a "slab" of metal with a hole in it moves up and down. This way, like Greg said, there is not area that can accumulated "stuff" that would cause the wedge to not completely seat when closing.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
